Not Going into Gear!
Old Aug 29, 2010 | 05:39 PM
Ol' Rusty's Avatar
Ol' Rusty is on a distinguished road
Default Not Going into Gear!
The truck has a turbo 350. When I pull down on the column shifter, nothing happens, at all. No noise, grind, pop or anything. Its stuck in park (I believe). It also doesn't matter what the transfer case is in. I just backed it up the drive way an hour ago. I just finished changing the pan and gasket on the tranny (other pan was in rough shape). It worked fine then, now, it doesn't. Could the shift shaft have broke? All the linkages and everything are still hooked up. Please help if you have something... Thanks, Jeff.
Old Aug 29, 2010 | 06:19 PM
Have a helper move the shift lever inside while you watch the linkage under the truck.
BTW, vehicle info??
Old Aug 29, 2010 | 07:12 PM
Ol' Rusty's Avatar
Never mind guys, I got it. The linkage was fine... it was low on fluid. I was looking at the dipstick wrong. If we had a "shoot yourself in the face smiley," I would insert it here. Thanks guys!
Old Aug 29, 2010 | 10:30 PM
blueblazer1982's Avatar
blueblazer1982 is on a distinguished road
low? you got a leak somewhere you need to address or you're compensating for a cooler or lines that you forgot about when you changed the fluid.
Old Aug 30, 2010 | 09:17 AM
Ol' Rusty's Avatar
Honestly, I think I just didn't put enough fluid back in after the pan change. We'll see how it goes from here; all is well this morning.
Old Aug 30, 2010 | 08:19 PM
allright. i did the same when i changed mine. i forgot to compensate for lines and the cooler
randrm
Jan 25, 2011 02:51 PM
Boiler_81
Dec 2, 2008 10:04 AM
willjones
Aug 18, 2008 02:34 AM
SnowRemorse
Jan 4, 2008 11:26 AM
BOTTLEDZ28
Dec 3, 2007 08:18 AM
