Odd blazer issue
Old Aug 21, 2009 | 06:13 PM
Max0000's Avatar
Max0000 is on a distinguished road
Default Odd blazer issue
Alright so I don't know if this is the right forum but im having an issue with my 1988 chevy k5 blazer
I bought it a few years back and havent done all that much with it Recently one of my fan belts broke and it over heated pretty good it didnt read line or anything but since then im having trouble getting it started It just sits there and turns and turns and turns but wont fire and start up? I got it to start up once or twice since then but when you go to give it gass it likes to die and once its off it wont start again Im not that great with cars and im kinda lost as to what to do...
So far ive replaced the battery, distributor cap, and rotary cap, i noticed that one of my spark plug wires got burned pretty good and Im gonna replace that tomorrow but was curious if any of you guys had a suggestion? anything would be much appreciated
Old Sep 4, 2009 | 09:04 AM
tom09's Avatar
tom09 is on a distinguished road
change the plugs and wires and when it does start check the exhaust and make sure there is pressure coming out of the tail pipe could be a blocked converter
Old Sep 17, 2009 | 06:30 PM
JoSHN's Avatar
JoSHN is on a distinguished road
It could be a multitude of things.
A clogged jet in the carb, a hole allowing air to suck in to around the carb or on the intake manifold, or it could very well be caused by the overheating
In actual technical things to look for first, run a vacuum test while you're cranking it to see if you have proper vacuum.
Then run a compression test to see if you aren't losing compression in the cylinders.
The overheating very well could have warped your heads.
Run these two checks and get back with the results.
davtak
May 27, 2012 08:41 PM
brian1971
Mar 9, 2011 06:22 AM
LittleT
Jun 26, 2008 01:17 PM
drperry
Jan 16, 2007 10:19 AM
Gonzo7
Oct 4, 2006 04:22 AM
