quick a/c question
Old Aug 6, 2010 | 05:02 AM
yarinzim's Avatar
yarinzim is on a distinguished road
Default quick a/c question
how much gas do i need to put in my blazer k5, 90, 5.7L A/C system?
Old Aug 6, 2010 | 04:49 PM
If by gas you mean R12 (what it was originally filled with) or R134a (if it has been converted), it is 1,463kg (3lbs 2oz).
Old Aug 6, 2010 | 04:50 PM
abig84's Avatar
My 90 pick up takes 2lbs 2 oz but might be different in a k5. There should be a sticker under the hood. But its probably worn off
Old Aug 6, 2010 | 06:08 PM
When they changed body style, the system capacity dropped. I took the info from my 90 R/V FSM.
Old Aug 6, 2010 | 11:41 PM
yarinzim's Avatar
sorry i forgot to mention - it's R134a
Old Aug 10, 2010 | 09:52 AM
yarinzim's Avatar
instead of opening a new thread i'll ask it here - it's all on the same installment.
when i tried to install the accumulator i noticed that when i bolt the nut from the evaporator to the accumulator, all the way in with an o-ring of course, the accumulator wobbles on the tube.
and i don't remember how it was when i removed it, but i guess the accumulator needs to sit tight in order to be air tight, right?
Old Aug 10, 2010 | 04:42 PM
It should be supported... (i.e. not flopping around)
So it doesn't tighten up when you tighten the lines?
blazinwoody
Engine & Internal
Jan 11, 2007 05:30 PM
88s10Blazer
Nov 10, 2006 05:49 PM
88s10Blazer
Sep 26, 2006 10:19 AM
athleticdawg26
Jul 30, 2006 02:43 AM
black19
Jul 2, 2006 11:58 PM
