Rear window motor problems
Old Dec 22, 2010 | 04:32 PM
smg614's Avatar
smg614 is on a distinguished road
Default Rear window motor problems
I have an 84 full size jimmy and having issues with the window going up and down. It has new glass and seals, but still not enough strength to move. Does anyone know where i can get a new motor? I have ordered a new cable from LMC, but have a feeling thats not going to solve the problem.
Old Dec 22, 2010 | 04:48 PM
Check the ground to the motor. I have seen a number of weak rear motors be due to an inadequate ground to the motor which grounds through the tailgate hinge. I would just run a new ground along with the rest of the wires into the tailgate. See if that helps things.
If not, the next thing might be to remove the regulator and make sure that it is lubed up good.
Beyond that, the motors are EXPENSIVE! I have two extras not including the one in my power window'd tailgate. I have the extras because of the problems that most people run into with a rear power window.
Old Dec 23, 2010 | 01:12 PM
smg614's Avatar
Thanks for the info, but just in case I need extras, where can a motor be found? I've searched the internet and haven't been able to locate one.
Old Dec 23, 2010 | 01:31 PM
They're out there. Google "K5 rear window motor" and see what turns up.
Old Dec 24, 2010 | 12:08 AM
jpimp's Avatar
jpimp is on a distinguished road
summit has them
http://www.summitracing.com/parts/AAZ-42-20/
Old Jan 14, 2011 | 09:59 AM
racer77's Avatar
racer77 is on a distinguished road
i just ordered one for mine trough advanceautoparts.com 60 some dollars
e602
91
Mar 8, 2015 04:53 PM
stewie455
Jan 22, 2012 09:02 PM
THePaRaSiTE5771
Jun 6, 2010 10:15 AM
billynjuls
Feb 16, 2008 04:24 PM
jumper02
Jun 8, 2006 12:09 AM
