Rear window won't go up
Old May 1, 2009 | 12:44 PM
blndreaper's Avatar
blndreaper is on a distinguished road
Question Rear window won't go up
Hello, new member here and I have a question.
I have a 1989 K5 blazer and the rear power window will go down but not up.
I have lubed the mechanical mechanism to allow the motor to pull the window down, but the motor doesn't even try to spin to put it back up.
I have checked it with a multi-meter and the "UP" wire gets no voltage at the plug for the motor, but the "Down" wire gets around 10-12 volts.
These voltages were taken where the wire plugs into the rear window motor and I don't know how to trace that wire back to where the problem could be.
Any help would be great, thanks!
The window does the same thing with the key and with the switch up front. The fuses are fine.
Old May 1, 2009 | 12:51 PM
oisinirish's Avatar
Have you checked the back of the switch. Does the switch give 12 volts when depressed for raising the window?
Welcome. BTW.
Old May 1, 2009 | 01:29 PM
I would go back to the switch as oisinirish said.
Old May 1, 2009 | 01:33 PM
blndreaper's Avatar
Alright!
I'll try that then I'll get back to you.
Thanks both of you!
Old May 1, 2009 | 05:51 PM
mech cb's Avatar
mech cb is on a distinguished road
Word-the wiring from the switch to the motor has no reason to go bad unless there's been some kind of mod that would affect it.
Old May 1, 2009 | 07:10 PM
Does the window work from the tailgate? You should be able to put it up and down from the key cylinder in the tailgate.
Old May 1, 2009 | 11:39 PM
blndreaper's Avatar
Nope, It does the same thing.
Down, but not up. Not even trying.
No mods to the wiring either.
Old May 2, 2009 | 01:25 AM
mech cb's Avatar
So how are you getting the window up right now? Or are you?
Old May 2, 2009 | 02:47 PM
blndreaper's Avatar
I am putting it up by removing the tailgate cover and disconnecting the cable drive from the motor and using vice grips to turn the cable.
It works, but it sure is slow..
Old May 2, 2009 | 06:43 PM
mech cb's Avatar
hahaha! Man, that sucks....
