Repleacing the rear??
Old Feb 7, 2007 | 06:42 PM
Chevyguy032's Avatar
Chevyguy032 is an unknown quantity at this point
Default Repleacing the rear??
Ok if you havent heard i blew my real to hell last week..well i am suppose to be getting my new(used one) only 40,000 miles on it..now when i go to replace the rear is there any special things have to do or is it jus the leaf spring bolts, and shock abosrber bolts?? I know the driveshaft has to come off to but i am just curious if there is anything else i need to do...
Old Feb 7, 2007 | 08:54 PM
bullridink5er's Avatar
bullridink5er is an unknown quantity at this point
Default RE: Repleacing the rear??
i just replaced mine in an 83 k5. its pretty simple, you will have to mess with the brake lines and bleed them after word, plus if you are not sure what size gears are in it, you will have to match your front and rear.
Old Feb 7, 2007 | 09:36 PM
i already know my ratios im jus curious on how hard it is removing the whole rear and replacing it with a different one..it seems to look quite easy but with me easy fixs become long pains
Old Feb 7, 2007 | 10:05 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
One way to not deal with the brakes is to take the axles out, then unbolt the backing plates, and tie them up. Remove u-bolts, driveshaft, shocks, old rearend, install new rearend, tighten u-bolts, shocks, u-joints,reinstall backing plates, axles, rear cover, fill with new fluid. No need to remove brake lines, parking brake cables, etc. Makes for a very clean transfer. I have done numerous rearends like this and I personally feel this is the better way to do it. Since usually the used rearends have worse brakes on them, and I really would not trust junk yard wheel cyclinders. Also this makes for a great time to replace the axle seals, so you have a fresh seal on things. Korey
e602
91
Mar 8, 2015 04:53 PM
brino1
Feb 25, 2011 08:05 PM
hcii
Nov 3, 2010 08:30 AM
1baggedblaze
Apr 13, 2010 04:52 PM
