Rough Idle 1990 5.7
Old Jul 3, 2009 | 09:12 PM
tjf76's Avatar
tjf76 is an unknown quantity at this point
Default Rough Idle 1990 5.7
I have a full size 90 with the 5.7. I have had problems with rough idle while in gear. I had a friend check the timing and it was set at 6 so he put it back to 0. That worked for about two week till I replaced the battery. I checked the idle and in park its about 550. I checked for any vac leaks and found none, any ideas????
Old Jul 3, 2009 | 10:38 PM
jhucks03's Avatar
jhucks03 is on a distinguished road
Have you cleaned or replaced the EGR valve? When was the last tune-up? A sticking pintle valve in the EGR valve or worn spark plugs/wires/cap/rotor could cause that.
Josh Hucks
Old Jul 3, 2009 | 10:46 PM
tjf76's Avatar
Josh Hucks
EGR has not been cleaned or replaced. Last tune up was july 08 plugs/wires/cap/rotor/fuel filter. EGR looks to be factory org. itsgot 104k on the the org. motor
Old Jul 4, 2009 | 08:50 AM
Have you checked or replaced the throttle body base gasket? These are known to leak causing a vacuum leak that is very hard to find.
How does the fuel spray out of the injectors look?
Old Jul 4, 2009 | 04:00 PM
bandidolenny's Avatar
Clean the throttle body and Idle Air Control. You are running AC Delco spark plugs right? I would also re-check the cap, rotor and wires... take a look at the plugs for any weird color or signs of fouling.
Old Jul 4, 2009 | 05:35 PM
tjf76's Avatar
Smile
I am running ac deco plugs and injector spray looks good. Will look over the other things noted. Thanks for the help. Will keep post up to date.
Old Jul 5, 2009 | 10:16 PM
tjf76's Avatar
I found 1 of my plug wires has been melted a little. It doesnt look to bad but could this be a problem? It now has a bad vibration at hwy speeds. I dont dare do above 65mph
Old Jul 5, 2009 | 10:27 PM
If you suspect the wires being a problem, mist them down at night with the engine running with as little ambient light as possible. If you see arching from the wires, they need to be replaced.
Old Jul 5, 2009 | 10:40 PM
tjf76's Avatar
Thanks for the tip, going to try it tonight
Old Jul 10, 2009 | 02:00 PM
tjf76's Avatar
Problems solved
Wires were bad and U Joint was bad
Thanks for the help
