-   Full Size K5 (1969-1991) GMT415 (1992-1994) Tech (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/)
-   -   Skid plate and gas tank removal???? (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/skid-plate-gas-tank-removal-39506/)
blbikerood Jan 19, 2010 06:13 PM
Hello again gang. I've determined I need to replace the fuel pump. Here is what I see as a problem. The truck has a reese hitch. The mounts seem to be in the way of the back two skid plate bolts if there are any. Couldn't get the reese hitch back two bolts off they are just spinning. It is my opinion that the bumper is going to have to come off , then get the hitch off, then the skid plate then begin on the removal of the tank.
Am I making myself work to hard?? Any help will be greatly appreciated. This is my first K5 and I am super excited. Thanks!
swartlkk Jan 19, 2010 06:17 PM
Sounds about right.
Once you get the bumper off, you'll have access to the nuts on the inside of the frame for the hitch and then you will be able to get the skid plate and tank down.
abig84 Jan 19, 2010 07:21 PM
i remember having the same problem but didnt have to move the hitch. i think the problem i had was i was able to get the skid plate bolts off but the skid plate wouldnt come out due to it hitting ht hitch. i just remember bending the tabs
blbikerood Jan 19, 2010 08:25 PM
how hard is the bumper to get off and on?
In the past I always paid for this kind of stuff to be done, but funds are low these days. Anyone know the socket size i'll need and if I can do it with a ratchet or will i need impact tools? thanks!
blbikerood Jan 19, 2010 10:03 PM
Some good news.
I came in and called it a night. But made good progress. The bolts were simple to get to once I used my head. For lack of a better term, the bumper "protector plate" that goes between it and the tailgate to fill in the gap had 3 or 4 bolts.
I removed it and had access to all the bolts I needed. The Reese Hitch DID NOT have to be removed. I removed the six skid plate bolts and after alot of wigglin and cussin, i removed it.
I then took off the top two gas tank strap nuts and found myself without a deepwell socket to remove the bottom nut.
Are there just two gas tank strap bolts or are there some toward the cab of the truck?
I hope that once I get off work tommorow that I can drop the tank and get that new fuel pump in. I'm going to post another topic and see what fuel pump people recommend. The one the guy had bought for it he mail ordered and it is some wierd brand i've never heard of. Thanks!
abig84 Jan 20, 2010 09:45 AM
Pretty sure there is just the two in the back. The front has the hook. Hate to bring this up but you can always cut a access hole into your floor to get at the pump if your blazer is on the beater side instead of going through this mess
swartlkk Jan 20, 2010 09:53 AM
Funny you should mention that. My K5 has such a hole:
http://i11.photobucket.com/albums/a1...teardown04.jpg
I would never do something like this on my vehicles, but since it was already there when I bought the truck, I plan on keeping the hole. I will be making it into an access panel with recessed bolts and a seal around the edge. The panel will be flush mounted to the floor when I am done with it. Right now it has part of a road sign over it (again, a bonus from the previous owner).
abig84 Jan 21, 2010 11:14 AM
lol. yep thats how i got my first gas tank access hole. the guy had a fuel injection intake on it and thats how he changed the fuel pump... actually came in handy cause a year down the road the sending unit took a crap.
blbikerood Jan 21, 2010 09:00 PM
Got her fired up and took her on her maiden voyage!
Fuel pump fixed my problem right up! Truck needs some basic stuff, tune up, shocks, but it will need a power steering pump right now! It whines like crazy just idling. Once i get that on, i'm going for the shocks and front carpet.
