Th350 swap help?
Old Mar 14, 2017 | 10:25 PM
Kkazee's Avatar
Kkazee is on a distinguished road
Default Th350 swap help?
I have a 92 k1500 full size blazer 5.7 4x4 and the stock trans (4L60E) is shot. A friend has a turbo 350 but it's 2wd, so I'm trying to find out what I would have to do to swap it into my truck, any info would be appreciated.
Old Mar 15, 2017 | 10:45 AM
LesMyer's Avatar
4L60E is an electronically controlled trans. 4WDs have output shafts specific to 4WD to fit into the transfer case. A 2WD TH350 is definitely wrong length and not electronically controlled. Probably doesn't fit transfer case, even if the TH350 was for a 4WD (which it isn't). PCM in the vehicle definitely won't like to not be controlling a transmission and torque converter. Torque converter probably won't be at right depth with your 1992 flex plate. Too many issues to overcome. Just buy another 4L60E, but get the right one. Sorry!
Old Mar 15, 2017 | 12:02 PM
chris015's Avatar
You must have a late production 92' if it does have the 4l60e. (it has a round main harness plug,700r4 has square). The 4l60e didnt come out till early 93'. As far as the pcm goes,the 350 will shift correctly,but your speedo will be off and the engine lights will stay on. Now,you need to find what tcase you can use,not sure on the tcase personally. If the driveshaft will work,then you can find a ujoint to fit it at napa or spicer. The flexplate you have should be fine.
Old Mar 15, 2017 | 01:27 PM
abig84's Avatar
the vehicle speed sensor should be in the transfercase so if you can actually pull it off i would guess the speedometer would work but not sure with all the rest of electrical disconnected. just seems like more work then its worth. you can bring the th350 to a trans shop along with your transfer case and adapter and tell them to install a output shaft in the trans that will work for what you want, did that before.
i know when changing from a th350 to a 700r4 which is pretty much a 4l80 i had to change crossmembers and driveshafts also on my 84 k5 blazer.
88Freddy
Apr 15, 2014 06:15 PM
payhellbay
Feb 16, 2013 11:12 AM
Razorburn71
18
May 15, 2011 04:52 PM
Danno85
Mar 13, 2011 04:28 PM
mefast
Feb 2, 2011 01:25 PM
