Tire shop said my 4x4 Yolk was bad, auto parts wanted to know...
What type?? I don't have a clue. Tire guy thought H type but told me to go ahead and order all 3! SO he didn't know anymore than I did. Is it a big deal to change these things out and is it sign something worse could be at stake??
With the yoke being bad is it still ok to put it in 4x4 till it goes out completely or should i avoid 4x4 all together??
Last edited by rriddle3; Jan 30, 2010 at 01:41 PM. Reason: COMBINING CONSECUTIVE POSTS
Tire shop said the yoke might need replaced, I locked the hubs put it in 4high had a bunch of clunking and then the shaft fell out. After about 45min I was able to move it 10ft and into the garage. I realize I can take off the shaft and drive the truck in 2 wheel drive, but as I"ve never done this, how do i get it off. It came off at the front of the truck and appears it just came off the threads. Also where can I buy what I need and what is the proper term for it. Thanks for the help!
Bring it to a driveshaft shop see if it can be fixed. 7/16 bolts at the axle and i think 5/8ths at the transfercase. If its not draggin the ground. Put it in 2x4 and drive it. Or tie it up if its to cold to deal with it
I understand more about these now. The drive shaft came out of the front diff. To me the yoke appears ok, but I am missing that nut that goes on the front diff, and all 3 u joints will need replaced. Of course the seal. I hope a local shop will have that nut, if not does anyone know where to order one?? The slip yoke seemed to work as it should. I took the entire shaft off with the four bolts that bolt into the xfer case, but it took an impact, and it bogged the impact down. So at least now I can drive it, just not very well in the snow!
you pulled the yolk out of the axle? cool. i wonder if something else is jacked up in there. those bolts are lock nuts and shouldnt just fall off. if worse comes to worse youll need a new ring and pinion. or better yet its a 10 bolt axle you can pick one up for $100 anywhere
