tranny blew up
Old Oct 17, 2012 | 06:44 PM
ericthughes's Avatar
ericthughes is on a distinguished road
Default tranny blew up
hey yall my transmission went out.how do i take of the transfer case from the back of the transmission.also is there a write up on this site on how to remove the transmission from a 78k5 or similar on this site?
Old Oct 28, 2012 | 03:19 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
Ever heard of this thing called the "search" function?
Old Oct 31, 2012 | 12:13 AM
abig84's Avatar
you got the np203 case right? that thing sucks. its so big, heavy and awkward, i would take mine out and just put down some old carpet and literally chuck norris kick that thing backwards when the bolts were loose and just let it fall. its about impossible to balance it on a little floor jack.
youll see when you get under there, pretty self explanatory. there is like 7 bolts bolting through the adapter towards the t-case, just unhook the driveshafts, electrical, linkages and whatever else, then take the bolts off
Old Oct 31, 2012 | 12:33 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
So theres the right way to suggest searching then your way.. Come on now.
Would renting a transmission jack help? Or do you have to get the truck in the air a ways for that? Just a thought.
Old Oct 31, 2012 | 10:49 AM
70-K5's Avatar
70-K5 is on a distinguished road
Harbor freight makes a good transmission jack that can be had for under $300... Since you're lifted you need to have one with a pretty good reach and since the 203's are so damn heavy you want something stable. Low-Profile Transmission Jack - 2000 Lb. Capacity
Will this work for everyday use? Like most HF stuff probably not.
But if you plan to pull more than one transmission/transfer case it's not a bad idea. Remember if you rent one you'll have to rent it once when you pull it and then again when you have to re install.
Other than that it is pretty simple to unbolt the t-case, no mystery bolts anywhere.
Old Oct 31, 2012 | 01:37 PM
chris015's Avatar
go to the junkyard and get a 1ftx1ft piece of 1/4" steel plate and weld some rebar on the edges then weld it to the center of a floor jack and sit the tranny on it.
Old Nov 2, 2012 | 01:43 PM
70-K5's Avatar
Don't know if you're familiar with a NP203 case. They are very heavy. They don't balance very well. And they are fairly large. A standard floor jack simply doesn't have a wide enough base to handle the shifting weight without tipping over.
This would work fine with a transmission that has an even weight distribution and a flat pan to sit on the plate but I'd be very wary trying to use it to take down a transfer case.
ark steve
Dec 21, 2011 01:25 PM
98jblaze
Apr 9, 2010 11:27 AM
Blazin NC
Dec 2, 2009 07:56 PM
shutterbug
Dec 31, 2006 01:26 PM
blazinloud
Oct 1, 2006 08:35 PM
