transfer case questions
Old Jan 15, 2013 | 07:23 AM
garrett8784's Avatar
garrett8784 is on a distinguished road
Default transfer case questions
The tail end of the transfer case on my 1990 full size Jimmy was leaking fluid for a while. I repaired it, but I was wondering where to add more fluid, what the fluid level should be, how is it checked, etc...
Old Jan 15, 2013 | 03:01 PM
rockp2's Avatar
Not sure of the transfer case in your truck, but to the best of my knowledge all transfer cases fill and check the same. Look for two "hex key" plugs. One high and the other low. On my NV 233 they are on the rear of the transfer and use a 10mm hex key to remove.
To check, remove the top plug. Put your finger in the hole. The fluid level should be flush with the bottom of the hole. To fill it I use a siphon with one of those rubber bulbs you squeeze.
If you wanted or need to change the transfer case oil...using a drain pan underneath you would remove the bottom hex hey plug.
Old Jan 15, 2013 | 03:21 PM
70-K5's Avatar
70-K5 is on a distinguished road
You should have a NP241C transfer case. ^^^basically correct above except instead of hex keys there will be a bolt, a big one that typically will use a large crescent wrench to remove.
Where was the leak coming from? Slip yoke, tail shaft seal, speedometer?
Note in the following page you don't need to remove the skid plate:
Autoblog Maintenance 101: Transfer case fluid change
Old Jan 16, 2013 | 06:03 AM
Default leak
It was leaking from where the tail shaft section was bolted to the main body of the transfer case housing. I fixed it with the Right Stuff from Permatex.
Old Jan 18, 2013 | 04:06 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
Fill plug is on the back of the transfer case, towards the top. It's a big 1 3/16 6 point socket.
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
1982blazed
Oct 26, 2009 03:13 PM
Clay_Assassin
Mar 4, 2009 12:48 PM
blazinwoody
Jan 1, 2009 07:38 PM
