Whining Sound
Ok, I have a problem with my truck, its an 87 Blazer with a 6.2L DD.
The problem is that when I'm driving and the truck starts to get up to speed, 3rd and 4th gear I start to get a whining noise, everyone says its coming from the back end, but to me it seems like its coming from the from driver side wheel/axle. Any help would be great!. |
could be the wheel bearings take them apart and check for any pitting or wear, replace and repack as necessary.
I'll take a look on Wednesday, if I'm looking at them I might as well change it, they can't be too expensive and I'm sure its the original so its about time to change them anyways.
Ok, I have checked the bearings and they both seem fine.
Its strange because the sound only comes on when i get into 3rd or 4th grea. And only under load aka giving it gas. |
replace your driveshaft u-joints. $20 says they'll be sloppy as hell when you take the driveshaft off.
Originally Posted by helo
(Post 430893)
well it could be your rear end going out. hard to say without being able to look at it.
Originally Posted by Z71_Guy
(Post 430952)
I was thinking the bearings, cant really see them unless you tear down the rear end. Did the fluid have a silver color to it.
Fluid seemed normal, no leaking into the drums and the axle had no wear on it.
