Whining Sound
Old Feb 27, 2011 | 07:49 PM
mafiaboy01's Avatar
mafiaboy01 is on a distinguished road
Default Whining Sound
Ok, I have a problem with my truck, its an 87 Blazer with a 6.2L DD.
The problem is that when I'm driving and the truck starts to get up to speed, 3rd and 4th gear I start to get a whining noise, everyone says its coming from the back end, but to me it seems like its coming from the from driver side wheel/axle.
Any help would be great!.
Old Feb 27, 2011 | 08:32 PM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
could be the wheel bearings take them apart and check for any pitting or wear, replace and repack as necessary.
Old Feb 27, 2011 | 08:44 PM
mafiaboy01's Avatar
I'll take a look on Wednesday, if I'm looking at them I might as well change it, they can't be too expensive and I'm sure its the original so its about time to change them anyways.
Old May 5, 2011 | 11:38 PM
mafiaboy01's Avatar
Ok, I have checked the bearings and they both seem fine.
Its strange because the sound only comes on when i get into 3rd or 4th grea.
And only under load aka giving it gas.
Old May 7, 2011 | 11:26 AM
helo's Avatar
helo is on a distinguished road
replace your driveshaft u-joints. $20 says they'll be sloppy as hell when you take the driveshaft off.
Old May 7, 2011 | 11:29 AM
mafiaboy01's Avatar
I've changed them about a year ago so I can't see them failing already.
Old May 7, 2011 | 06:36 PM
Z71_Guy's Avatar
well it could be your rear end going out. hard to say without being able to look at it.
Old May 8, 2011 | 09:57 AM
mafiaboy01's Avatar
Well when I opened up the axel tontakena look at the bearings everything seemed fine and I had my autonteacher look at it too, couldnyou be more specific about what could be failing?
Old May 8, 2011 | 08:47 PM
Z71_Guy's Avatar
I was thinking the bearings, cant really see them unless you tear down the rear end. Did the fluid have a silver color to it.
Old May 8, 2011 | 09:01 PM
mafiaboy01's Avatar
Fluid seemed normal, no leaking into the drums and the axle had no wear on it.
