wont start
i just got a 1972 blazer with a 350 it ran well the first 2 days then decided it didn't to start or even begin to turn over, i replaced the starter after that didn't work i replaced the battery, im stumped if anyone has any suggestions it would be great.
Did you check for power at the starter with the ignition switch?(have someone turn the key like you were gonna start it)
it has power, the starter spins when the ignition is turned on but not when you trying to start it you have to do it by hand, its like its not engaging
was there a shim between the starter and the block?
nope there wasnt but the new one came with one, i didnt install it
are you saying that the starter will not engage to the flywheel? Use the Shim!
The ignition isnt even controlling the starter. im bypassing the ignition switch by hand and its spinning but isnt starting it. the solenoid and the starter are new.
wont the shim push it farther away from the flywheel though
If the starter spins but DOES NOT engage with the flywheel to turn the engine over,the clearance is off and you have to use a shim or two to pull the starter away. But if the starter is just spinning and the bendix isnt being thrown forward then theres a problem with the starter/solenoid
If the starter is too close to the flywheel it will just spin because it cant mesh with the flywheel teeth to turn the engine over |
ok im just confused why my key isnt turning the starter. electrical?
