1992 K5 Blazer TBI running rough and overheating and stalling
Old 08-25-2010, 06:41 PM
Pruney81's Avatar
Pruney81 is on a distinguished road
Smile 1992 K5 Blazer TBI running rough and overheating and stalling
I'm trying to help out a buddy of mine who has a 92 K5 Blazer TBI. Here goes. When you first start it in the morning it will idle really rough and gives off a SES light, then the temp climbs to the red really fast. After seeing it overheat so quickly I shut it off and noticed the coolant was boiling in the upper radiator hose.
From the little reading I've done I think it might be the coolant temp sensor and/or the thermostat.
I'm going to replace both of these tomorrow but I'm not too familiar with these engines so I'm not sure if it's not a cracked head or bad head gasket maybe?
I can't see any evidence of the coolant or oil mixing. Just the terrible loping/surging idle for about ten minutes then it'll stall out.
I turned up the throttle cable and started it back up and it overheated within a minute. Any ideas?
Cheers!
Old 08-25-2010, 07:14 PM
Have you checked the plugs or done a compression/leakdown test? You may have a head gasket problem.
Old 08-25-2010, 07:57 PM
Pruney81's Avatar
Is it possible it's just the temp sensor and maybe the thermostat causing it to heat up so quickly?
Old 07-13-2011, 12:36 PM
roody0067's Avatar
roody0067 is on a distinguished road
Default 92 blazer
I have a 92 Blazer that has never failed me. It will not start now. It is not getting fuel to injectors so I have rebuilt top half of throttle body ,replaced fuel filter,replaced injectors, tested electrical connectors with noid light and getting strong pulse. Checked fuel pump it is working and I am getting fuel to the throttle body but fuel not coming out of injectors. Please Help
Kube
03-31-2013 06:40 AM
90rusty
10-17-2009 07:53 AM
jannes_z-28
09-04-2009 11:58 PM
LWegner
13
06-25-2009 06:23 PM
s10blaze
11-04-2008 05:17 PM
Quick Reply: 1992 K5 Blazer TBI running rough and overheating and stalling
