04 rear gate and window won't open
Old Mar 28, 2011 | 02:10 PM
OHBlazer's Avatar
OHBlazer is on a distinguished road
Default 04 rear gate and window won't open
I have an 04-4 door Blazer. "Gate Open" light was suddenly lit up. I opened and closed the back window, ever since I cannot open the window or back door using the remote or any other method. It does make the normal unlocking sound when using the remote and door panel switches. Any suggestions on how to get this apart without going to a mechanic? (I have disconnected the battery already)
Old Mar 28, 2011 | 03:46 PM
mdehoogh's Avatar
You can manually open it from inside. You'd need to pull the plastic panel and there's a metal lever to release the glass. There should also be a rod spanning the width of the gate that controls the latches along the edges.
I have the dropdown tailgate like a pickup rather than the gate that lifts up but I've manually released the door and glass on both types of gates before. However, I can't remember if the plastic panel can be removed from the liftgate while its closed.
Here is a picture of mine that shows the location of the glass release (blue circle)and the latch release (green arrows).
Jim84
Nov 6, 2024 07:15 PM
e602
91
Mar 8, 2015 04:53 PM
ensembledwar
Mar 7, 2010 12:13 PM
kimber
Nov 5, 2006 09:24 PM
oldcoot
Oct 29, 2006 01:48 PM
