1969 Blazer CST. Restore or mod?
I have a 69 Blazer CST that I am in the process of doing the sheet metal work on and I didnt know if this thing would be worth restoring stock or just lift it and keep it as a toy. If I go the stock route I imagine I would be putting it up for sale upon completion but I have never had a lifted truck before so I will probably keep it if I make it a big toy. I cant find out much info about this thing other than they made 4935 total in 69. If anybody knows anything that would be great. Thanks.
1969 was the first year of the Blazer. (1970 for the Jimmy) Is it original? Does it still have drum front brakes?
If it is in decent shape then I would try and keep it as original as possible... there are only so many of them out there.
When I say "original"... I am not opposed to a lift and tires. You can always remove a lift and put on stock rubber later. I just wouldn't cut any sheet metal or weld on external roll cages, etc...
It is in terrible shape but that doesnt bother me. It is all original, 307 I am guessing due to the tiny carb. Drum brakes and all. Repainted silver at sompoint, last registration was 1982 and the original color appears to be orange.
RESTOMOD!!!!!
I would keep as much original as you can, and then mod it to YOUR taste.....
I would also look into a bigger motor to spin the tires, but freshen up the old motor and keep it around for sentimental value if you ever decide to make her back to original
The only part that is gonna suck is cutting apart repop shortbed bedsides to make the bedsides for this one. Rear floor is perfect and frame is somehow perfect. Front floor and rockers are the same as a truck so they are easy. Classic industries sell repop doors thank god cause they were unrepairable.
