1996 Cavalier
Old Apr 7, 2007 | 03:27 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Default 1996 Cavalier
I know its been a while since i've been on here, So first thing to say is whats up everyone. Anyway I bought a 96 Cavalier for gas saving reasons. But when I drive for a while, about 30-50 miles, my oil light comes on only when I stop. My oil level is good. Oil was just changed 2 days ago. Anyone know what the problem may be? Thanks.
2.2 liter
156,xxx miles
New head gasket last year
Old Apr 7, 2007 | 09:34 PM
filstoy's Avatar
filstoy is an unknown quantity at this point
Default RE: 1996 Cavalier
https://blazerforum.com/m_73871/tm.htm
I just answered this same question so check the link above. I can tell you it's not a good thing though. The following is a service bulletin for your car.
Document ID# 42522
1996 Chevrolet/Geo Cavalier
[hr] Oil Pressure Diagnosis and Testing[*]Low oil level. Fill to full mark on oil level indicator.[*]Incorrect or malfunctioning oil pressure switch[*]Incorrect or malfunctioning oil pressure gauge[*]Improper oil viscosity for the expected temperature[*]Oil pump worn or dirty[*]Malfunctioning oil pump pressure regulator valve[*]Plugged oil filter[*]Oil pump screen loose plugged, or damaged[*]Excessive bearing clearance. Replace as necessary.[*]Cracked, porous or restricted oil galleries. Repair or replace block.[*]Oil gallery plugs missing or incorrectly installed. Install plugs or repair as necessary.[*]Oil diluted by moisture or unburned fuel [/ul]
Old Apr 12, 2007 | 05:26 PM
So do you think its wise to drive far?
Old Apr 12, 2007 | 09:02 PM
filstoy's Avatar
That's a tough question to answer. I had a Cutlass which was doing the same thing that I had decided I was just going to drive until it quit and it ran another 60,000 miles. With low oil pressure though, eventually something is going to start knocking so who know how long it will go before it burns up ? Since it's already got 156,000 on it, I would guess sooner than later before it spins a rod bearing. Wish I had a better answer for you.
Old Apr 12, 2007 | 09:41 PM
Well thanks for all your help. (not sounding cocky, kinda does, but I don't mean it)
staticwolf21
Feb 2, 2013 08:38 PM
chris015
Mar 10, 2012 06:51 PM
gmbwrenchn
Oct 26, 2010 09:08 PM
old skool luvr
Jun 5, 2010 12:58 AM
dawne fischer
Dec 21, 2004 12:16 AM
