2001 zr2 blazer rpms jumping all over and truck dies
it started a few days ago while driving home my truck felted as if it bogged out for a second and then rpms started jumpin all over the place and then truck died it wouldnt start up after that. i towed it home and have replaced fuel pump and filter new plugs and wires new cam position sensor and crank sensor new cap and new plastic piece inside that as well as well as new ignition coil. the truck now starts up and dies sometimes and sometimes it idles fine at 600 rpms but then i go to drive it and it now does the rpms jumping all over and tries to die but if i keep givingh it gas it strugglers but will correct itself but not for long im at a loss as to whats wrong, is there anyone who can help me figure it out. i never had issues with it before except randomly very few times did it chug for a second while on cruise control at 70mph. is there a chance ive missed something? its the 4.3 vortec with 173k miles on it. its getting fuel and i have the fuel pressure tester it has the right pressure while running and off. even when in park it idles in right range but it just dies rpms only jump all over when im driving not in park. im gettin fuel and spark.
To test - hook up gauge, turn key to ON, not CRANK, listen for the fuel pump to run its prime cycle (approximately 2 seconds), Turn key off, notate initial reading at prime cycle cutoff, have a 10 minute union break, and recheck reading, at no point should it go below 55PSI, and 60PSI is avg.
Joecrack85
07-22-2012 12:17 AM
grtbrwn
02-21-2012 05:53 PM
blazinbowls33
01-08-2012 04:15 PM
