2002 ZR2 has a "pitch/dive"
I have a 2002 Blazer ZR2 that has a "pitch/dive" to it when I crest a hill or go over a raised center bridge. Like the front end drops and goes to the left. I have done much of the front suspension and it still remains. is this normal? If not normal, has anyone experienced this and found a way to fix it?
I just finished the front shocks. That was my initial thought. They weren't very old, but tried anyway. Have done the idler arm as well as the steering damper. Tie rods and ball joints seem solid. no play in torsion that I have seen. Has me at a loss at this point. the very first time I had it I replaced the shocks and it went away. Now can not seem to get rid of it.
Have you installed a lift or adjusted the torsion bar all the way up? these trucks do not like maxing out the adjustment on the t-bars. look at the adjustment bolt. if it is all the way in, that might be your issue.
I had/have the same problem.
I found it is worst when my steering is out of alignment, camber is not centered. I've done drive way alignments, with SOME improvement.
I am suspecting it might also have something to do with the anti sway bar missing(mounting location on the passenger LCA broke, so it was removed). Sinnce it was removed, it has had a "float" I can not get rid of.
edit: I have a 99 4 door 4x4 lifted 2.5", but same sympton
. There is no adjustment in the rear.
