4 wheeling question
Old Mar 2, 2013 | 09:17 PM
canuck blazer's Avatar
canuck blazer is on a distinguished road
Default 4 wheeling question
Hi guys I have a question 2002 chev blazer 4x4
I got stuck in the snow today and noticed only the driver rear and passenger front tires were spinning is this normal never had this problem with my 1989 ford bronco 2 this is a new one to me
Old Mar 2, 2013 | 11:07 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
Normal yes, it's says 4x4 but it's actually 4x2
Old Mar 2, 2013 | 11:10 PM
4x4blazerguy's Avatar
4x4s without limited slip are one drive wheel on front & one on the rear. The wheels with least resistance will spin.
Old Mar 3, 2013 | 06:51 AM
Default 2002 chev blazer
So are all the blazers from this era the same setup? thanks for the answers
thought something was wrong, it's the first time getting stuck with it, had to be pulled out by a jeep 2door. This will make me more aware of the challenges..
Old Mar 3, 2013 | 09:00 AM
duxtoyz's Avatar
duxtoyz is on a distinguished road
put a locker in the rear and ul never be pulled out by a heep again. lol
Old Mar 3, 2013 | 07:53 PM
Smile
NO.
Both my 97 & 98 had Limited Slip rear Ends. If you read your option sheet it tells you. There is a very good & complete post here on this site that explains how to read it. (RPO numbers) On my 97 & 98 the sheet was in the glove box.
Old Mar 3, 2013 | 08:11 PM
Karcinagin's Avatar
Karcinagin is an unknown quantity at this point
You would be looking for the RPO code G80, and if you have if it may not work as it is a gear locker so it locks up with some force on it that sometime causes them to fail. My old 93 2x4 has a g80, still working at 230K, and my CC with 118k also working.
Old Mar 3, 2013 | 08:30 PM
ohsofly's Avatar
G80 is the "posi" option on these trucks. Looks for those numbers on your glovebox. Since you were doing the one-wheel-peel you do not have a G80
Old Mar 3, 2013 | 08:40 PM
Karcinagin's Avatar
Or a Failed one?
I am not 100% but I believe the locker is designed to unlock at 20+mph so for it to work best you need to keep it slow for it to work.
Old Mar 3, 2013 | 09:28 PM
thanks so much for that info i was sure i had posi i will check for that number.
my 2002 has just over 313 thousand km runs like a top would being a little hung up cause that to happen/
