4Hi/4Low stay lighted up
This is my second post.......
I have a 98 S10 Blazer, with a 4.3L, and I have had a continuing issue with when changing out of 2Hi into either 4Hi or 4Low, both the 4Hi/4Low lights stay illuminated on the 4WD switch. It will go into 4Low, and only momentarily into 4Hi before disengaging - it sounds like it goes into 4Hi, the motor actuates, but goes right back into 2Hi. Any thoughts?
Odd, Is the vacuum hose to the pull-cable actuator under the battery good? And is the solenoid on the firewall engaging.
yes I replaced the vacuum actuator, the cable, and that mechanical solenoid that bolts into the differential - I replaced all three of them. And when you ask about the solenoid are you talking about the control module on the right side kick panel? If so, it has also been replaced. But I have not yet replaced that switch that’s part of that four-wheel-drive solenoid mechanism on the front differential.
I replaced the vacuum hose to the actuator, and I do not have a solenoid on the firewall. Also, I have verified that the spring and shifting fork work correctly.
Here is another interesting fact, it will go into low range and the 4wd works, but it will not go into 4hi.
Well I have also replace the encoder motor and the transfer case control module on the left kick panel……..also, I can hear the encoder motor actuate when I push the 4low button, and it takes a second or two, but I also hear it shift into 4hi…….?
its almost like its missing its gear, or cant detect that its in what gear it thinks its in.
