-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   4wd to 2wd (https://blazerforum.com/forum/general-chat-34/4wd-2wd-62414/)
W2JGA Aug 23, 2011 03:59 PM
4wd to 2wd
Sometimes, one begins to wonder.
Anyhoo, is it possible to remove the front CV shafts and still be able to drive the vehicle? So as to increase fuel economy? Of course, I would reinstall them prior to winter time. Would the shaft from the transfer case have to come out also? If it trips a SES light or 4wd light, i'm not concerned. Thanks.
xgiovannix12 Aug 23, 2011 04:02 PM
I know someone who did
He deleted the shafts Transfer case and i dont know what else but its possible
Hes going to prob reply to this thread later on tonight
W2JGA Aug 24, 2011 09:14 AM
Are you saying he removed the front cv shafts and the transfer case? Or just the shaft from the front diff to the transfer case?
chris015 Aug 24, 2011 10:08 AM
Okie dokie Here we go.
Yes you can remove the front cv axles. BUT heres the deal. you gonna have to break em to make it work,so you gonna have to buy new ones when you wanna replace em in the winter. The wheel bearings need the outter cv ends to keep the bearings from failing. You know the outter part that slides into the wheel? yea thats gotta stay in it. So you remove the cv axles,put the cv in a vice and beat the heck out of it until the outters pop off. Or theres a tiny carter clip inside the boot you can pull and it'll slide off. slide the outters back in the wheel hub and bolt it all back in. Whalla no front cv's Justs just when you need the new ones back in,save the outter old ones for when you wanna remove front wheel drive capability. As for the transfer case,I didnt remove it,it would of been a pita to sort things out. I just removed my front driveshaft so nothing is turning,and less weight. I even removed my front diff. Ive shaved over 900lb on the blazer. He's on a diet. and you can feel it! my 4wd didnt work and i never used it.
xgiovannix12 Aug 24, 2011 12:36 PM
See i told you he will respond in the thread =) ^^
pettyfog Aug 24, 2011 12:54 PM
.. As for the transfer case,I didnt remove it,it would of been a pita to sort things out. I just removed my front driveshaft so nothing is turning,and less weight. I even removed my front diff. Ive shaved over 900lb on the blazer. He's on a diet. and you can feel it! my 4wd didnt work and i never used it.
Good stuff and I'm gonna save that info in case I need it.
My only question and it pops every time I see someone say 'remove front driveshaft'... what do you seal the TC seal with? To keep the TC fluid from leaking out? Or dirt from getting in.
Oh... and if it were me and the CV's were good, I'd pull the clip. Or get a pair from junkyard.
chris015 Aug 24, 2011 02:37 PM
Pulling the clip is a pain,you need a GOOD bottle of degreaser before you can even see the clip. its in there! About the seals,i was worried as 1st about it. I pulled my driveshaft and nothing leaked,i pulled back and forth of both ends and nothing slid out.I looked and couldnt see a way of alot of dirt to get in it. Its been like this since January and Ive had no issues or leaks thus far. So its a go!
John,you know this is my area of information! :) lol Its whatcha get when you get bored one day,drink a bunch of beer and started getting into things that you didnt know nothing about.
Between removing my rear seats,carpet from seats back,ac delete,driveshaft,front diff,and cvs gone,4x4 selector system and bunch of random things i dont remember it brought the weight down from 3410 to 2470 with my 280lb ass in it. I couldnt believe i could ever get a s10 blazer to weight just over a ton. Between 3.42 gears and a 4.3 ive done everything i can think of other then heads and cam,Its fun to drive.
jh94 Mar 18, 2013 04:02 PM
Hey im sure this isn't the place for this but i have a 94 4x4 4.3cpi auto S10 Blazer and my tranny went out. im thinking of going to a 5 speed. this is the first auto s10 ive had lol. Does anyone know if Id need a different length rear driveshaft? Thanks
1sttimejimmyowner Mar 18, 2013 08:47 PM
Very interesting topic if I ever end having problems with 4wd I know how im going to take care of it LOL.How much better gas milege to you get?
richphotos Mar 18, 2013 09:23 PM
See I have thought about this a lot, could you not just get control arms from a 2wd, and spindles ect and do it without breaking the cv shafts for the front hubs?
