4x4 wiring plug doesn’t exist
Old Nov 7, 2020 | 04:05 AM
Kyle Liebrecht's Avatar
Kyle Liebrecht is on a distinguished road
Default 4x4 wiring plug doesn’t exist
Can someone tell me where the plug wiring for the 4x4 switch, wires to in the 1997 Chevy blazer? I have the transfer case, the switch and the driveshaft going from the transfer case to the front and back axles but no lights on the switch and no engagement to 4x4 and upon further inspection I found out I don’t have the plug at all and after inspecting grounds and power wiring I haven’t found the wiring for it like the videos stating so I may just re-wire a plug for the 3 button switch from Amazon but need a working digraph to find out where to go to start that kind of job IF I can’t find the plug already in the blazer :/
I have the three button, (7 pin plug), switch so I have 2hi, 4low, and 4hi
help!?
Old Nov 8, 2020 | 04:35 AM
Has this Blazer been modified?
It's not clear what you mean by: " I have the transfer case, the switch and the driveshaft going from the transfer case to the front and back axles but no lights on the switch and no engagement to 4x4..."
Are you modifying a 2WD to a 4WD?
Would be very uncommon not to have the respective connector (plug) for the switch just behind it in the dash.
Old Nov 9, 2020 | 03:00 AM
Yeah sorry no I just bought the truck like this and when I went to try to engage the 4x4 with the switch to see if it worked, no lights no nothing lit up and no engagement. So when I got home the first thing I did was check my wiring inside the vehicle and found out this problem but this blazer came, from factory with 4x4 and had everything still installed when I got this blazer and didn’t look to be tampered with except the plug and wiring going to the back of the switch behind the dash from the fuse block (and from the transfer case I believe) and where I live, I need it to work lol (because of the climate) but I have the fuses, relays, driveshafts, axel shafts(all 4 axels), 3 button switch, and the transfer case just no wiring behind the dash GROUNDS ARE GOOD ASWELL! 🙂
Old Nov 9, 2020 | 09:31 AM
ProCycle's Avatar
ProCycle is on a distinguished road
On my 2000 Blazer the transfer case shift controller is under the passenger kick panel. It's plugged in to the main chassis harness. Some previous owner may have replaced your dash harness with one from a 2WD.
Old Nov 10, 2020 | 02:21 AM
So, just to make sure we have properly understood your problem:
  • It used to be a 4x4
  • Somebody has either removed or put a 2WD harness in as ProCycle suggested
  • You have the proper fuse box
  • The wiring from the fuse box to the switch is missing
  • The wiring from the transfer case to the switch is missing
Not sure how the 97's controlled the transfer case. Should there be a separate TCCM?
How does the vacuum actuation look?
Try having a look at rockauto's literature for that model. Sometimes you can get by the original factory manuals on DVD. But not the HAYNES or CHILTON. There are at least two manuals the service and the electrical & diagnostics.
Maybe somebody has the wiring diagrams for the 97 4x4?
Old Nov 11, 2020 | 12:40 AM
yes your points you’ve stated are Correct but this vehicle is a 4 x 4 vehicle it was never a 2 Wheel Dr. vehicle it was always 4 x 4 so I don’t know why the switch or plug is not there where it should be and I didn’t know that you can change the harness from a 2 wheel drive blazer in to mine witch is a 4x4 blazer I will have a look at the wiring on the passenger kick panel and see what I find
Old Nov 11, 2020 | 12:45 AM
okay yes I did see when I was wiring my subwoofer in for the positive wire on the passenger side I did see that there was a ecu looking silver box there attached to the passenger side kick panel by the door so I’ll take a look and see maybe the harness was pulled back behind the glove box assembly too ? I’m not sure. Will update you on the situation once I get it apart again lol
Old Dec 10, 2020 | 05:20 AM
so I did some wire digging when I had my dash completly apart and out of the vehical and couldn’t find the 4x4 switch plug connector anywhere, so I went under the vehical and did a better in depth check for everything 4x4 related and I noticed I do not have a front driveshaft that goes from the transfer case to front axle assembly so I’ll have to pick one of those up from a parts blazer BUT.. my new question is could I manually change the transfer case to 4x4 (once I get a front driveshaft) by taking the motor controller off the transfer case and turn the *** counter clockwise or clockwise and should that not change/engage the 4x4 with out the interior connector, witch Would then make my 4x4 work? Manually lol?
762mm
17
Nov 21, 2024 11:36 AM
TY~DY
Mar 4, 2013 05:12 AM
2001BlazerLSCan
13
Feb 18, 2013 04:09 PM
arolon
13
Mar 12, 2009 02:22 PM
quinanite
Dec 10, 2007 11:43 PM
