89 S10 Blazer Suspension Lift ???
Old Nov 14, 2011 | 03:42 PM
89Recon's Avatar
89Recon is an unknown quantity at this point
Default 89 S10 Blazer Suspension Lift ???
I am looking to get a suspension lift for my 89' S10 Blazer 4WD 4x4 I already found a 3" body lift from Rough Country but I also want a suspension lift and all they offer is a 2.5" and I want at least a 6" if not bigger does anyone know of a place that sells suspension lift kits for my Blazer?
Old Nov 14, 2011 | 07:22 PM
ChevyBlazerChick's Avatar
Lift Kits, Tires & Wheels by 4 Wheel Parts
If you're looking to spend a couple thousand...
Old Nov 14, 2011 | 08:32 PM
89Recon's Avatar
On 2nd thought I found this kit will this one work it is only a 6" suspension lift but seems nice I just want to know if it has everything needed to do the lift.
http://www.4wheelparts.com/Lift-Kits...PK776B#active1
Old Nov 14, 2011 | 10:38 PM
91chevywt's Avatar
91chevywt is an unknown quantity at this point
Superlift Part K776B - 6 inch Suspension System with Bilstein Shocks by Superlift
Yes, plus you'll need an alignment. $2,300 is a lot of money though, for what you end up with. If you're going to spend money, you're better off doing a solid axle swap up front and figuring out how to make it work, or paying someone else to figure it out. Like a 4x4 shop, speed shop, etc. The front axles on these trucks aren't that great especially with big tires
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
