98 Blazer no heat
Old Dec 13, 2009 | 09:04 PM
cferris2103's Avatar
cferris2103 is on a distinguished road
Default 98 Blazer no heat
i have a 98 v-6 blazer. i have flushed out the heater coil and i have replaced the thermostat. i only seem to get warm air out of the vents when the engine is over 2500 rpm, otherwise it is just cold air. any ideas...?
Old Dec 13, 2009 | 09:06 PM
Does the engine come up to normal operating temperature (about 1/2 way on the gauge)?
Old Dec 13, 2009 | 09:16 PM
the engine actually rarely gets above 1/2 way on the temp. gauge. it seems the engine is being cooled normally.
Old Dec 20, 2009 | 02:17 AM
acooper114's Avatar
acooper114 is on a distinguished road
Mine did that too. I bought a cheap flush n fill kit for the radiator and flushed it out. A bottle and a half of 50/50 anti freeze and it's hotter than it's ever been.
Old Dec 20, 2009 | 06:37 AM
1 Wicked V's Avatar
1 Wicked V is on a distinguished road
check your hoses going to the heater core...both should be roughly the same temp when at operating conditions...do you see coolant circulating while it running? Mine just blew cold air until I flushed the heater core directly with a garden hose...outlet to inlet first, then inlet thru outlet..rad cap, thermostat, and water pump are good areas to check as well...dex-cool has done nasty things to many vehicles from what i hear....
CSCustomCars
Nov 22, 2010 08:24 PM
Lodi Dodi
Nov 12, 2010 06:26 PM
mcaanda
Dec 15, 2009 08:31 PM
nash_686
Nov 25, 2009 06:43 AM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
