99 Blazer
Old Jul 7, 2009 | 12:17 PM
kbreck's Avatar
kbreck is an unknown quantity at this point
Default 99 Blazer
Changed both frt hub assemblies,now my ABS is very sensitive (summer).ABS never engaged in summer now coming to a normal stop can feel ABS,hit the brakes real hard ABS really comes on.
Is this normal ?????
Thank You
Old Jul 7, 2009 | 09:23 PM
What brand did you go with for the hub assemblies?
Sounds like one or more of your WSS are just putting out too low of a voltage when the wheel turns. You can test the mV-AC output. It needs to be above 250mV. If it isn't, you can file down the mounting surface on the hub assembly.
Either that or you could return it for one that works.
