Abs/brake light fix
Old Oct 23, 2010 | 12:28 PM
jlucey2's Avatar
jlucey2 is on a distinguished road
Default Abs/brake light fix
Hello just want to let everyone know there is a fix for the abs /brake light coimng on it's not the module its the hub assembly in front wheel just replaced my left front hub assembly and found lots of play inside first had to jack up front grab tire from top and bottom try to move it if you have movement you need a new hub assembly comes self sealed no greasing required looked at old one gear inside assembly was chewed up from hitting abs sensor which is on the hub assembly also comes with new one on it good luck to all having this problem
Old Oct 23, 2010 | 12:33 PM
blueblazer1982's Avatar
blueblazer1982 is on a distinguished road
sometimes it is sometimes its not the hub. i've replaced 3 hubs and it has not fixed mine. however my balljoints snapped in two while going down the road. and cut the abs wire in 2. probably shorting the module out since they do not fuse them.
Old Oct 23, 2010 | 12:37 PM
jlucey2's Avatar
Yes that might be your problem being wire was snapped just curious if you had any heater core issues i seem to have gurgling sound in heater core checked for leaks none backflushed core some small particles came out heat works fine in truck did a pressure test on system no leaks at all?
r_marczak_83
17
Mar 9, 2013 10:33 AM
Bertbart
Jun 16, 2012 04:53 PM
95redblazer
Mar 8, 2011 01:30 PM
tim_dean
Mar 20, 2008 08:44 AM
Dodge Guy
Oct 25, 2006 08:48 AM
