ac hot then cold
Old Jul 28, 2012 | 09:25 AM
ragen's Avatar
ragen is on a distinguished road
Cool ac hot then cold
i have a 2000 blazer ac works but blows cold air for 5 seconds and then blows hot air for about 5 seconds, then repeats .after reading past questions and answers seemed like it should be the actuactor motors gear for the blend door.sure enough gear was broken and i replaced only to have the same results. even after recalibration the cycling sounds keeps going on after the 45 seconds said to be needed.is it the cumpter climate control switch or is the blend motor bad or?
Old Jul 28, 2012 | 09:36 AM
kingkill83's Avatar
kingkill83 is on a distinguished road
check two things:
coolant level and if your oil is milky....
and two, whens the last time you ahd your a/c flushed? bad bushings on ac can cause this they dry rot over time,.
stevenhousden
Jul 6, 2014 05:56 PM
Mandrwj
Apr 10, 2011 07:32 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
outdoorxman
15
Jun 12, 2007 05:06 PM
Inferno
Oct 22, 2006 08:56 PM
