any easy way to test 4x4?
or do as i do after a hard play session..park at the bottom of an incline..put it in which ever 4 you prefer..and see if she does any pulling...(luckily i have a slightly inclined drive way) so i can test with purpose or what CB said...(close to home/a shop granted) lol incase it is fudged..and are stuck for good lol
I have the shift 4x4, and I was messing with it today and the lights on the panel don't work. I put it on 4 high, drove a little, stopped, and then put it back in 2 high, but seeing none of the lights are working I really cant tell if it shut off. I may just be a little paranoid but don't want to be riding around in 4 wheel drive wearing the transfer case.
Drive in a circle slowly, about 10 mph, in 2wd first. Then put it in 4wd and you should feel it binding up, and kick back and forth... its kinda hard to explain but you can tell the difference if its working right.
so in 4wd I should feel it almost locking down a little? having to give it a little more gas?
better question, if I only had 2 jackstands could I test it by just jacking up the front end and starting it up to see if the wheels spin or not?
this might be of help hope your 4wd is working!
why would the g80 affect the turn-test for 4wd? all that particular rear end will do is get power at BOTH rear wheels instead of one at that speed...
I'll try this when I go out a little later.
