axel swap question
I am wanting to swap the ifs front in my 96 s10 blazer. I was just wounder what axels would work. I am want to use a 10 bolt front and a 12 bolt rear you think they will work for a daily driver. I read some where that a dana 30 will fit and I can still use the stock t-case the pumkin will be on the right side. Or would if make more sence to go with the 10 and 12 and change t-case and stuff.
I was also woundering what leafs I should use. front and rear
take a peek at this to get your wheels turning: Click me for a quick link to a very basic-ified post with pics of what you are looking at getting into
the dana 30 is kinda small. unless its gonna be a street truck. try to get a set out of the older smaller broncos or jeep wagoneers. they will be close to the same width. 10 bolts stick pretty far out in some states they have laws against how far a tire can stick out past the fender
AHHH!
made link easier to find then
if dana 30 is too light, what should he shoot for, the 44? 30 should stand up at least equal to the rear end. should be more than enough for a trail ready/road savvy ride.
BTW: danna 60 in front, corporate 14 in the rear, 4.10s at a minimum, 350 SBC, 4L80E, NP205, 33x12.5 MTs, custom cage, and open trails = my dream Blazer
ok pick a dana 30 up out of a 87 wrangler (for free) so couldnt turn that down it is complete just needs wheel bearing replaced but it is that vaccum style so my next question is how do i replace that to lock out hubs if there is a way
still need to get leafs
