Blazer Fuel Mileage Craziness
I think it is hilarious that my 2001 Blazer 4x4 (4500#) gets 14 mpg combined, 17 highway - runs so fine, starts with just a touch, obviously controls fuel mix, has new calipers & brakes and factory size tires properly inflated. Put the same vehicle on a 2800# trailer and pull it with my 2004 Avalanche 4x4 (6500#) and I get 14 mpg on the Interstate running 65mph with the A/C on. Just did a trip to near Detroit and back for my yearly Krown rustproofing and did the Blazer too this time. 400 miles RT at 14 mpg. It just doesn't add up!
One case is a 4.3 V6 pulling 4500#. The other is a 5.3 V8 pulling 13,800# It's not wind resistance. Anyone know what the 1998-2000 5.7 V8 pickups got for fuel mileage? Is the LS engine that much more efficient?
On my 1999, 4dr, 4wd, 3.73:1 rear end, I'll approach 18-19 mpg on long cross state highway trips but combined I'm more like the 14 mpg.
Although only 3 years different in model year, perhaps the engine management for the Avalanche engine is just much better due to it being a new generation of software? It is amazing what the engineers have been able to do with both fuel economy and power over the last few decades.
Between computer settings and gear ratios I actually think there isn't much one can do to gain any in millage. After building my Morf the curb weight has dropped by close to half, millage has not changed from being a s15 Jimmy - 14 / 15 town 16 / 18 Hiway - One would think there should have been a noticeable gain .....
I'm trying to remember... I think what I want to compare is the BSFC (Brake Specific Fuel Consumption) of the two engines as a measure of efficiency. I'll see what I can find and how it might be applied to our vehicles.
Possible explanation.
Once I had my 94 4.3 V6 taken apart I was appalled by the pistons and compression ratio it really had.
Measured out at 8.8 : 1 compression, and non existent squish. Might be a possible explanation.
I'll find out once the build comes together if the engine is knock limited and therefore running rich.
Used to see the same effects on all engines with very small venturis vs. displacement.
Running fine at very low rpm, even with decent fuel mileage but increased fuel consumption at higher rpm.
The rear end ratio might be less important than the total ratio in each gear vs. wheels and resulting rpm at the same speed.
Wow I wish I got 15+
My 04 averages like 11-13 around town or on the highway...
But I guess that's what happens with you lift it, put on oversized tires without regearing, and ruin the aerodynamics by cutting off the front lower valance for a winch and install gigantic LED bars on the roof...
But I never expected it to get great mileage. That's why I drive my old Saturn around daily. That 21 year old beater averages about 30mpg lol
