-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   Blazer Operating Temperature (https://blazerforum.com/forum/general-chat-34/blazer-operating-temperature-62551/)
masterchf117 Aug 27, 2011 06:06 PM
When I drive my Blazer without the air conditioning running it runs at 193 degrees. If I turn on the AC it will run between 197 - 198 degrees.
What temperature does your Blazer run at under these conditions?
warthogdriver Aug 27, 2011 06:22 PM
a little bump in temp seems normal when running the air.
that sounds like its ok to me.
nice member name by the way.
swartlkk Aug 27, 2011 06:51 PM
Not that the gauge is that accurate anyway, but sounds fine to me as well. Do you have an aftermarket gauge installed (if so, where is the probe) or are you looking at the PCM data?
bdbrissette Aug 27, 2011 07:36 PM
My Blazer seems to run about the same temp, even though I have an electric fan now. I have seen other blazers and s10's all run between the 190 to 210 range and never had any problems.
xgiovannix12 Aug 27, 2011 07:48 PM
Mine runs 200 normally 210 with ac on and 210 towing a trailer with ac on when i do have it on
m3ch Aug 28, 2011 08:47 AM
mine always operates under 210, it usually is around the "quarter" mark on the gauge idk what the temp is
chris015 Aug 28, 2011 09:36 PM
You have a 180 stat? Mine is in the center between 100 and 210,thats on the old analog clusters.
Rottidog Aug 28, 2011 11:57 PM
Mine is usually around the 203F mark on a hot day. That's with the 2 - 1730cfm E fans on the shroud I made at work & a 180F thermostat. Keep in mind that mine does run a little warmer due to the supercharger.
masterchf117 Aug 29, 2011 09:03 AM
I have a ScanGauge2 in my vehicle so that is where I am getting my data from.
nathaniel1988 Sep 12, 2011 12:18 AM
hey is 220 to hot for my engine? it ran between 200 and 210 before replacing both coolant sensors and thermostat(195) trying to chase this check engine light ghost lol
