Blazer will not start
I was driving my 2001 blazer home the other evening and it just dies on me after getting it home I checked the fuel pump its pumping the fuel relay isn't bad the fuel filter is not stopped up when I put fuel in the throttle body it will start but dies whats wrong?
You are not getting fuel, If you put fuel into the throttle body and it starts then dies.
You need to do a fuel pressure test and report back with the results Key on engine off reading, then let it sit and see what it drops to in 10 minutes |
Okay thanks will try that
Should have 60 pounds pressure +-. Mine had 30 or so and would bleed off. Regulator was bad.
Sorry for double post
The fuel pump may fail causing the engine to stall and not restart.Technicians recommend to replacing the fuel filter every 30,000 miles to help prevent undue strain on the fuel pump.generally we have to replace fuel pump twice in one year.
Buy a A/C pump Yeah cost more but they LAST
if it starts and runs about 30 sec then dies it might be your map sensor ? you might not be getting enough voltage to it you can use a wire to jump the plug in on the map sensor if you unplug the map sensor use jump wire one end in both sides of plug if im rite then you should be able to start your blazer good luck its passenger side of throttle body on mine I have 4.3 ltr good luck hope it works for you!
jump the plug with wires not map sensor sorry
Originally Posted by gregorian69
(Post 638430)
OP. The pump may have ran, sounded like it was running, but could not be pumping enough fuel to start the truck and keep it running. Since these engines need quite a bit of pressure for them to start and run. If you have done the pressure and leak down test. report back with the results if you have not figured out the problem. If you have figured out the problem, also report back with how you fixed it so we can help others in the future. |
