General ChatChat about all things Blazer (and related vehicles). Off-topic stuff should be in the lounge, and all mechanical problems should be posted in the proper forum.
Very nice! Did you run into any problems with the shifter cable/linkage? My body lifted Blazer doesn't shift through the gears fully, and I'm suspecting the Linkage wasn't adjusted with the lift.
What kind of ball joint spacers did you use? Have any problems with them?
No problems yet, Only issue was when I installed them I had to switch the bolts to nut on the bottom otherwise the bolt sticking out rubbed the rim. Offset rims would cure that though
