Body lift finally done
Old Jul 30, 2013 | 06:54 PM
newguy's Avatar
Default Body lift finally done
Never rush through things, took 4 days but I`m happy with it
Attached Thumbnails Body lift finally done-100_0700.jpg   Body lift finally done-100_0699.jpg
Old Jul 30, 2013 | 07:26 PM
95BlackGA's Avatar
95BlackGA is an unknown quantity at this point
Very nice! Did you run into any problems with the shifter cable/linkage? My body lifted Blazer doesn't shift through the gears fully, and I'm suspecting the Linkage wasn't adjusted with the lift.
Old Jul 30, 2013 | 07:32 PM
newguy's Avatar
Everything seems to fine, just drove it up and down the street for now.
Old Jul 30, 2013 | 07:36 PM
95BlackGA's Avatar
Yours probably has the shift cable, and not the metal rod linkage. Thanks though!
Old Jul 30, 2013 | 07:40 PM
newguy's Avatar
Yes Cable
Old Jul 30, 2013 | 07:45 PM
50lb_cat's Avatar
What kind of ball joint spacers did you use? Have any problems with them?
Old Jul 30, 2013 | 08:00 PM
newguy's Avatar
No problems yet, Only issue was when I installed them I had to switch the bolts to nut on the bottom otherwise the bolt sticking out rubbed the rim. Offset rims would cure that though
Old Jul 30, 2013 | 08:13 PM
warthogdriver's Avatar
looks good man.
almost has a military feel with your wheels and the dark green color.
Old Jul 30, 2013 | 08:27 PM
gitch93's Avatar
gitch93 is on a distinguished road
looks good man u need wheel spacers
Old Jul 30, 2013 | 09:16 PM
cleburne red's Avatar
Looks good!!
Now just go get some manly looking shackles to go in place of those cheap little d rings they give you!!
