brakes go out
Old Dec 30, 2011 | 10:37 AM
justinbrown1993's Avatar
justinbrown1993 is on a distinguished road
Default brakes go out
Hi I have a 2000 chevy blazer 2in suspenion lift, 2in body lift, and 31's the reason I'm posting this is as soon as I put all these things put on my brakes started going out. I have replaced all brake parts and the master brake. They go out whenever I cut the wheel all the way to either direction to were they don't turn anymore they go to the floor, but I can pump them back up. I have now found any pinching or over exstention.
Old Jan 2, 2012 | 10:35 PM
abig84's Avatar
seen this issue before after putting a 2inch lift on a blazer for a customer at work. what was happening is those stupid new upper control arms are were actually hitting the caliper or caliper bracket (this was like 8 months ago so im trying to remember) thus pushing the caliper piston back into the caliper causing the pedal to go the the floor. so check that. turn the wheel all the way one way and lay under it with the truck on the ground and see if your calipers are hitting anything under full turn.
basically what we did was grind down the control arm a hair to stop the caliper from hitting. i have pictures of it somewhere, if i can find them ill post them
Old Jan 2, 2012 | 10:43 PM
abig84's Avatar
found them. yeah the upper control arm was hitting the caliper pin causing the caliper to push in.
so just ground down that corner on both sides and took care of that
Old Sep 17, 2012 | 03:29 PM
cant believe i have been driving a year with them doin this, i pretty much gave up hope but i just got back on here. thank you so much ima go try this!
Old Sep 17, 2012 | 03:43 PM
and this will not cause any structural damage to the control arms?
Old Oct 1, 2012 | 12:40 PM
Leo_p's Avatar
Leo_p is on a distinguished road
Do your brake hoses also look all chewed up? I'm having the same problem but my brake driver side hose is all chewed up I'm thinking something is on pinching it think steel brake hoses will fix the prob? Anyone ever do this? Anyone recommend good inexpensive ones?
Old Oct 1, 2012 | 03:12 PM
bluedevil500's Avatar
bluedevil500 is on a distinguished road
Make sure to check your regular components as well. Master/slave cylinder, brake fluid and hoses.
Although it's probably lift related, it could have just been coincidence, as well.
poertsch
Apr 23, 2016 01:05 PM
goslats
15
Jul 31, 2015 09:19 AM
mowermechanic
Jan 31, 2012 09:01 AM
218persuader
Aug 20, 2010 06:11 PM
marketmagoo
Oct 30, 2009 10:48 AM
