Brakes : New rotors/pads/wheel cylinders/shoes
Old Mar 21, 2014 | 11:00 AM
95BlackGA's Avatar
95BlackGA is an unknown quantity at this point
Default Brakes : New rotors/pads/wheel cylinders/shoes
'91 S-10 Blazer - 4.3L - 4 wheel drive - NO ABS (came stock with ABS)
So... Just replaced the rotors and pads up front. Wheel cylinders and shoes are less than 6 months old, with less than 3000 miles on them. Removed ABS (Didn't work, didn't want to try and figure out what was wrong with it). New lines for the front. Full brake siphon with new brake fluid then bled them properly.
Symptoms : Brake pedal is low, goes almost to the floor when stopping (about 1/2" from bottom throw). Brake pedal stays firm with engine off (good master cylinder?), drops properly when starting (good vacuum?), albeit drops low.
No fluid leaks at cylinders/calipers.
I'm honestly starting to suspect the Vacuum Booster, but I don't want to just go and drop $150 for a new booster, if that's not going to fix it.
EDIT : ABS Removed 'cause 1. It never worked when I got the truck. 2. I thought maybe it had air in the line and was causing these issues. Removing the ABS system didn't change a thing. Same issues.
Old Mar 21, 2014 | 01:05 PM
abig84's Avatar
theres probably air in the system somewhere. i dont know how it ends up getting in there but ive done jobs where i clamp the lines off doing front calipers and somehow air get sucked into the back. try bleeding everything again, all 4 tires, master cylinder etc and probably get lucky.
booster shouldnt make pedal go low unless something mechanical broke inside of it. if the vacuum dies off in it it will just be harder to brake
Old Mar 22, 2014 | 06:43 PM
95BlackGA's Avatar
Re bled today, still dropping real low, and is soft. I did find out I over torqued my caliper pins and shredded the threads. That's fixed. Still soft brake pedal.
Maxboost25psi
27
Mar 4, 2013 05:26 PM
Sway_89S10
Jan 29, 2010 12:23 PM
flawlessbmxr
Dec 3, 2009 09:08 PM
lionel2
Feb 4, 2008 04:45 AM
