a/c vacum line.
Old 05-28-2009 | 07:07 AM
stevenf's Avatar
stevenf is an unknown quantity at this point
Default a/c vacum line.
My a/c will only blow out of the defrost vents. After driving a while it will barely blow out of the regular vents. I'm sure its just a loose vacum line. Where is the a/c vacum pump?
Old 05-28-2009 | 07:34 AM
a/c vacuum pump - aka. the engine.
Old 05-28-2009 | 09:51 AM
stevenf's Avatar
Then where is the vacum line?
Old 05-28-2009 | 09:53 AM
What are you driving???
Old 05-28-2009 | 01:03 PM
stevenf's Avatar
97 jimmy 4x4
Old 05-28-2009 | 03:32 PM
The vacuum line runs from the intake to a 'T' where it splits down to the vacuum switch on the transfer case on one side and into the firewall on the other. It may go through another 'T' before going through the firewall in which case one side of the 'T' would go into the firewall and the other side would go to the vacuum reservoir. The vacuum reservoir should be located inside the driver side fender.
Once on the other side of the firewall, it runs into the vacuum harness on the back of the HVAC module in the case of the manual HVAC system or into the vacuum control module in the case of the automatic HVAC system.
Dale/PA
10-04-2014 02:16 PM
BLAZERMAN911
02-23-2011 10:44 AM
louie424
09-06-2009 10:05 AM
banshee386
04-14-2009 07:15 PM
ken01blazer
12-29-2008 08:25 PM
Quick Reply: a/c vacum line.
