Castrol German Blend 0w-30
Old Sep 16, 2008 | 12:58 PM
AutomagicLS1's Avatar
AutomagicLS1 is an unknown quantity at this point
Default Castrol German Blend 0w-30
anyone using it in their blazer?
Old Sep 17, 2008 | 02:00 PM
AJBert's Avatar
Default RE: Castrol German Blend 0w-30
Nope. I use 5W-30 just like GM told me to use.
Old Sep 17, 2008 | 02:18 PM
Well I put some of this miracle german castrol oili in my blazer. Right off the bat I noticed the engine was quiter and also gained oil pressure. 10-15 psi on startup and when the motor is hot at a stop light the pressure is 10-12psi higher when idling hot.
Old Sep 17, 2008 | 08:10 PM
Kage0113's Avatar
Kage0113 is an unknown quantity at this point
Did you run synthetic before you put this kind in?
Old Sep 18, 2008 | 08:57 AM
GeorgesBlazah's Avatar
GeorgesBlazah is an unknown quantity at this point
Whether he used synthetic or not before this oil wont make a difference. Unless you are trying to cover up some engine problem, I wouldnt use the thicker oil.I use 5w-30 just like it says.
Old Sep 18, 2008 | 01:11 PM
Kage0113's Avatar
I don't know cause when I put my mobil 1 full synthetic it made the same things he's describing happen to my engine, it was quieter and everything ran smoother. That's why I'm asking because if he already had synthetic in, and this oil made even more of a difference I'd want to know. Otherwise if this is the first time he put synthetic in, it seems to be just like any other synthetic oil.
Steinbruchsoldat
Mar 29, 2017 09:36 PM
BlazinMike89
Feb 28, 2009 11:51 AM
cr8390
Feb 17, 2009 08:23 PM
N2BLAZIN
Jan 4, 2009 10:31 AM
88s10Blazer
Jun 19, 2006 06:50 AM
