dam oil filter will not come off
Sorry, thought you unbolted the housing not ripped the can off.
I've had to use a chisel & rubber mallet to brake the seal, just make sure you do it on an angle in the direction you would of to remove the filter can.
All you need is to lube it with some motor oil. I would tip the old filter sideways, and put some used oil from that on my finger, and use that to lube it. Never had any leaks, or trouble pulling my filters off. Make sure the whole gasket has a coating.
I had a problem getting mine off once as well. I ended up removing the oil filter adapter from the fender and using a vice and a pipe wrench. It was on there like a good thing. Screwdriver trick didn't work nor a strap wrench or filter wrench. Stupid dummies who don't oil the seal first :@
i've come close to the same situation you're in now, although the damn filter finally came off, just before reaching that state. you haven't told us what you're working on (most of us have presumed it was a 4x4. if it is, take the filter adapter off the truck, hold it really well in a vice (or have a trusting friend hold it tightly) and tap it off with a hammer and chisel. just be careful not to nick the sealing surface.
even if it's a 2WD, same method applies.
have you just bought this truck? i'm kinda curious as to why the filter is so stuck (i'm sure we all are).
don't any of you guys prefill the filter?
true.
does anybody know how this guy made out? his last post was @ 5:35 tonight, just wondering if he's still under the truck cursing or crying...........
