DEAR GOD!!! t5he rust
well, decide to finnly do someting about the disturbing amounts of rust under my truck, i have pb(from work) wish works well a dremel with a small wire wheel and a large wire wheel, and more sugguestions on removing this stuff ?
BEFORE
AFTER
this is wat was left afther just cleaning the obvious rust
the diffe was literaly caked in with rust, took about whole can of pb to remove it, and most of its still there
BEFORE
AFTER
I actually just finished doing my frame. All i did was go over it with a wire brush a few times to knock off most of the rust. Then i used rubberized coating on it. It cost about $10 a can.
Rust is not my friend! I cut it out and welded in new panels. Make sure that you seal your work right away or it will rust fast.
The rear diff plug can be removed with a 3/8" ratchet and short extention.
[IMG]local://upfiles/2910/87F1C5688BC2475EA58A27CF08958383.jpg[/IMG]
[IMG]local://upfiles/2910/D23A4BF01F4642D08247DD785DD36F97.jpg[/IMG]
[IMG]local://upfiles/2910/1822DACB779E49B8A61ED9D8DD89DBFD.gif[/IMG]
Yeah I did mine, too. you might want to look into the rear differential cover. I know of 2 ppl and me that theirs rusted through. For future reference, I would be sure that your fill plug will come out ok, I broke a snap-on extension off in mine and couldn't get it back out. I ended up tapping a hole in the new cover(After it was installed, which is why I say check the fill plug first, much easier to do if the cover is on a bench) and installed my own fill plug. It is at the same level as the original. My blazer came out of Ohio, down here I really don't have to worry about rust unless I go to the beach alot. Oh! and I could only find a cover at the dealer. I think it was around $20
