It does everything, well...except START! Is it my fuel pump?
Old Apr 24, 2012 | 11:36 PM
Melrock83's Avatar
Melrock83 is on a distinguished road
Unhappy It does everything, well...except START! Is it my fuel pump?
Im so PISSED at my blazer!! Ive put over $1400 in it since Oct, and I love it obviously. So I get in it Sunday and I turn the key and it tried to start but didnt. It whines and whines but will not fire. I dont no how to check to see if its getting gas BUT it acts like it isnt. In my experience, I really believe its the fuel pump. It ran great the last few wks, go figure and so this is totally out of no where. Nothing happened to give me an inkling something was goin out. Its gona cost over $200 to get it replaced and thats not including the tow from my driveway, but should I go with my gut and just change the fuel pump since I feel its the issue, or is there something else I should check first?
Old Apr 24, 2012 | 11:40 PM
Melrock83's Avatar
And just to give an idea of what kind of relationship my blazer and I have..when I told my best friend that once again my blazer was broke down and wouldnt start she replied "That Bytch REALLY hates you!!" And I think she may be right!!
Old Apr 25, 2012 | 07:23 AM
Sonj's Avatar
Sonj is on a distinguished road
Did you ever figure out if it was the pump? A somewhat simple test is to get a rubber mallet and have a buddy tap the tank a few times while you try to crank it over. If it starts then it probably the pump. If not then it could be something else.
I dont know about the 95 blazers but i do know that 98 and up have the pump/ fuel assembly all in one which is like 400+ bucks. Also, do you have a plastic tank or metal? If metal I suggest getting a new tank with the new pump. There is nothing like putting in a new pump and using the old tank and a few week later it stops due to it getting clogged by rust.
Old Apr 25, 2012 | 04:27 PM
50lb_cat's Avatar
You need to get a fuel pressure gage and hook it up to the check valve. There is a good article in the diy section. Post your numbers back, all else is shooting in the dark.
Old Apr 25, 2012 | 04:47 PM
xgiovannix12's Avatar
i start by diagnosing the fuel system
96+ Fuel System Diagnosis - Blazer Forum - Chevy Blazer Forums
Old Apr 25, 2012 | 09:00 PM
Brian_D's Avatar
Turing the key on just enough for the radio to come on, listen for a hum. it should hum for about 3 seconds. if you don't hear that, it is prob the pump imo. but like xgiovannix12 says, do some more research before spending money on a pump.
Old Apr 25, 2012 | 09:37 PM
chris015's Avatar
If you DONT hear the hum check the fuel relay 1st.
Just to save you alot of grief if it is the pump,DO NOT BUY one from a local auto parts store aka a aftermarket. it will not like it. Blazers are PICKY when it comes to pumps. only use ac delco or delphi pumps. You might say "well,this ones only 39.00 and it has a warranty,so il try it" you will get sick of dropping tanks. ive done and and i wont do it again.
bluecherry2002
Aug 24, 2012 11:26 AM
bobby099
Mar 20, 2012 07:13 PM
todster
Jan 10, 2011 10:27 AM
YOURCONNEXX
Oct 21, 2009 07:10 PM
