ECM short circuit
Old Feb 25, 2025 | 02:38 AM
gregory brychta's Avatar
gregory brychta is on a distinguished road
Default ECM short circuit
Hello I need a wire diagram for the 92 Chevy blazer s10 with the tahoe trim. 3.4 v6 tbi. I知 getting a short at the ecmignition fuse when the key is turned. I知 not getting any fuel to the injectors. But my fuel pump is priming when I turn the key
Old Apr 5, 2025 | 11:10 AM
daveca's Avatar
1995 factory manual, PCM power is thru the ECM Batt fuse 9.
The ECM IGN 10 fuse supplies the injectors, PCM, and ignition module. A shorted ignition module transistor would do that. Disconnect the power to the distributor and try again.
If not, disconnect the injectors.
After a 2 second fuel pump prime, there wont be fuel pressure without ignition pulses, that prevents fuel flooding and fires
Tmcguire
Oct 27, 2022 05:03 PM
Lucki Mutha
Oct 15, 2019 07:07 PM
Xavier
Jan 31, 2012 06:22 PM
TZFBird
Jun 2, 2011 09:14 AM
FImports
Aug 21, 2007 01:47 PM
