When I got my blazer 2 years ago this upcoming Sept. I got a Lubrico 2 year warrenty for $900, a fairly comprehensive one. It covered a lot of things like motor, trans, transfer case etc & when the front drive shaft went 8 months later they 'chose' to have it replaced with a good used one. A new one is around $600 & the replacement has been fine. It matters to whom you take the vehicle to (that they approve of) & the people working on it. Also I have to take it in for a chassis lube & oil change every 5000k or 3 months. Kinda pisses me off that I'm not allowed to do it myself though.
Originally Posted by Rottidog
(Post 344662)
They made you use a used driveshaft? They better have paid for new U-joints and making sure it is as solid as a new one! $900 for a warranty? Is that per year or total? If that is per year, I would probably just start putting that money aside so I can throw a rebuilt engine or trans in when this thing hits 200k in another 10 years (when I learn how to do that that is). |
hehehe it was for 2 years, any lubricated item that fails they replace, the drive shaft was used but they had new u-joints installed & I've umm 'tested' it quite a bit
as for the oil changes its so they know it's done right (like thats a given at any fast oil change place) BUT when I get them to do it I'm covered! I have paperwork to mail or fax them as proof the oil was changed & zerks/grease nipples were lubed etc. If I did the oil change theres not "legit" paperwork. It's them covering their azzes to cover yours. If my transmission goes - I'm covered If a differential goes - I'm covered If the engine or a bearing blows or a rod throws etc - I'm covered & there are a lot of other things they cover ... but oddly when my oil pressure sending unit went tits up they didn't cover it lol, $85 part & hr's labor but they did cover the rear pinion seal $15 part & at least 2 hrs labor It's paid for itself so I'm OK with it |
