Flat towing a 1998 Blazer
Old Mar 29, 2009 | 02:57 PM
JSolCanby's Avatar
JSolCanby is on a distinguished road
Default Flat towing a 1998 Blazer
Hi - I have a motor coach and would like to be able to tow my 1998 Blazer 4 wheels down rather than using a tow dolly. The Blazer is an automatic 4X4. My mechanic says that as long as its in neutral and the transfer case (electronic switch) is in neutral that I should not have any problems. I'm looking for 2nd and 3rd opinions before I mount a tow bar on the front. Any comments or advice is appreciated.
Thanks. Joe
Old Mar 29, 2009 | 06:37 PM
rriddle3's Avatar
Here's what your owner's manual says:
If your vehicle has four
-wheel-drive it cannot be dinghy towed (towing with all four wheels on the ground). A four-wheel-drive vehicle must be towed by flatbed.
Take it for what it's worth.
Old Mar 29, 2009 | 07:38 PM
It comes down to what you have for a transfer case.
If you have a 3-button dash switch, then it is possible to flat tow the truck. You will have to disconnect the rear driveshaft prior to flat towing it.
If you have the 4-button dash switch... I think you may be able to flat tow it, but you have to make absolutely sure that the front driveshaft does not turn as you move the vehicle along with disconnecting the rear driveshaft.
gawilcox
Nov 8, 2013 10:12 AM
ComputerNerdBD
Oct 24, 2013 12:09 PM
Dube2
Jul 26, 2013 01:55 PM
Russ T Nut
Dec 7, 2011 08:05 PM
Cecil
Sep 20, 2009 10:03 PM
