Fluid leak
I am wondering if anyone on here would have any advice on a washer fluid leak. I have found that when either the front or rear washer is used, the washer fluid leaks from the rear driver side of my 2000 chevy blazer, above a black, fuel related type box. I can't seen to get to the line near where I think its leaking. Any advice will help!
If you go to 2nd Gen Tech you can search for threads related to your problem. I had the same problem but only with the rear. It was leaking in under the carpet. You might try removing the trim piece nearest the rear lift gate. It just pops off. Under it you'll find the small hose that links the washer fluid reservoir to the rear washer. Mine was unhooked and that's what was causing the problem. I just put the hose back on the 90 degree connector and used some zip ties to secure it. My truck is a 2-door, but I don't know if it matters.
BrinkDiamond
Mar 2, 2014 03:50 PM
DaleA
Jan 13, 2009 08:50 PM
