Frame and body swap questions...
I've got a 2000 Blazer 4dr 4x4 ls. I won't lie. My Blazer is a rust bucket. You should see the rust on the passenger rear quarter panel! I can stick my hand in there and almost pull off a chunk of it. The rocker panels are also rusting a bit, mostly bubbling. Additionally, right under the gas door, it's got a rust spot. Instead of batting cancer, I'd rather try to tackle a full on swap. Maybe even buying a crate motor. The dilemma I have is figuring out which frames I can use since there are many different wheel bases; which doesn't seem like too much of a problem. Wouldn't I just have to switch out the drive shafts? But then there is the 2wd and the 4wd, which I have heard have different frames. Can I use a 2wd frame for a 4wd or would I have to do welding or anything? I plan on doing this not anytime within the next few months, but I would like to plan. Does anyone have any other suggestions?
Frames are different 2wd to 4wd, 2dr to 4dr, and ZR2 for a total of 5 different frames. But if you have a 4dr 4wd, then you just need to look for a 4dr 4wd. The body is the same between a 4dr 2wd and a 4dr 4wd though so if you are just going to swap out the rusted body for a less cancerous one, why worry about the frames at all?
Originally Posted by swartlkk
(Post 659239)
wouldnt it just be easier to find another complete blazer and use parts off the old rusted one when you need them... i mean body swaps arent easy and you could find a good blazer for around the same price that is still running? i mean you need to buy another one to do the swap anyway??
Originally Posted by dragoon1101
(Post 659497)
