Front Mount Hitch Uses?
Old Jul 7, 2013 | 07:57 AM
HostileJava's Avatar
HostileJava is on a distinguished road
Default Front Mount Hitch Uses?
I just added a front hitch for a cargo carrier, but I'm curious as to what other uses they have?
Old Jul 7, 2013 | 08:44 AM
rexazz2's Avatar
guys that cant back up a trailer use them
have seen winches mounted that way to be able to use front or rear
keep a eye on your temp gauge , don't want to block the air to the rad
Myself I would have tried to tuck it up and behind the tag holder , put the tag holder on a spring loaded hinge
Old Jul 7, 2013 | 08:54 AM
newguy's Avatar
I`ve also seen for winch mounts front or rear. Good idea really Hitch Receiver Mount for Winches
Old Jul 7, 2013 | 09:19 AM
It was designed for the blazer, bolted right in to the towhook/oil pan cover bolt holes.
Curt Manufacturing 31021 Front Mount Receiver : Amazon.com : Automotive Curt Manufacturing 31021 Front Mount Receiver : Amazon.com : Automotive
That's pretty cool.
Old Jul 7, 2013 | 10:07 AM
rexazz2's Avatar
I understand the bolt on part
Not a fan of seeing that hanging down but that's my opinion only
Old Jul 7, 2013 | 12:10 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
Put one on mine a month ago, also a curt I painted it the same color as truck also not a fan of it not tucking but figuredid takean extra bottom plastic peace I have and camouflage it a littlefab workand some epoxy and I hope it work out. I got it for a wench/cargo hauler.
Old Jul 7, 2013 | 01:08 PM
Badco's Avatar
Badco is on a distinguished road
you could always keep a few tow straps in the back along with a reese hook adaptor. I've heard that the hooks are not super durable and another mounting point would spread it out. just in case you gotta pull someone out
Old Jul 7, 2013 | 10:50 PM
tibby's Avatar
A front mount hitch is more efficient at pulling vehicles out of a rough spot like a mud hole in my opinion. Hook a d-ring and make it look like a bull, vicious! Just my .02.
Old Jul 8, 2013 | 09:32 PM
cleburne red's Avatar
A lot of guys set up a winch to be able to be mounted either front or rear, but I've read that the pin that would hold the winch into the receiver tube really isn't build to hold up to heavy-duty winching. Especially if you have a 12k lb winch, and a super stuck truck. It's advised to get two receiver tubes for winch mounting. It would probably be ok, anyway, though, but that's what I've read.
Old Jul 9, 2013 | 02:52 AM
newguy's Avatar
Or drill it out and use a grade 8 bolt
